PROBLEMAS CODIGOS DE ERROR VAG COM
Publicado: 23 Feb 2013 17:27
por jero
hola e hecho un scan a mi toledo y no se interpretar que arreglo tiene si lo puedo hacer con el vagcom todo o alguna cosa hay que sustituir, este es el escaner:
VCDS Version: Release 11.11.3
Data version: 20120401
Saturday,23,February,2013,16:01:33:32264
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ3R024893 Mileage: 251160km/156063miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 FK
Component: 1,9l R4 EDC 0000SG 3357
Coding: 00002
Shop #: WSC 06402
VCID: 5EB980A1DA2CB49
VSSZZZ1MZ3R024893 SEZ7Z0B1632852
2 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - Intermittent
17948 - Vehicle Speed Signal
P1540 - 35-00 - Signal too High
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 00001 001 00001
VCID: 336F0115512E491
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 C
Component: 1M-CLIMATRONIC X0603
Coding: 00043
Shop #: WSC 00046
VCID: 2241F451AED4D09
7 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-10 - Blocked or No Voltage - Intermittent
01272 - Positioning Motor for Central Flap (V70)
01271 - Positioning Motor for Temperature Flap (V68)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-00 - Open or Short to Plus
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
00797 - Sunlight Photo Sensor (G107)
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0004
Coding: 13113
Shop #: WSC 06441
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 802 D
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05122
Shop #: WSC 03429
VCID: 2757E545C5F6351
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
00667 - Ambient Temperature Signal
30-10 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
VCID: F0E54E19B0B8B29
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: 3E Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 06402
VCID: 3A712C312644B89
Subsystem 1 - Part No: 1C1959801A
Component: 3E Tõrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C1959802A
Component: 3E Tõrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811A
Component: 3E Tõrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812A
Component: 3E Tõrsteuer.HR KLO 0004
3 Faults Found:
01389 - Tailgate Open Switch (F124)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00930 - Locking Module for Central Locking; Rear Left (F222)
End ---------------------------------------------------------------------
Saturday,23,February,2013,16:11:32:32264
Coding: 00002
Shop #: WSC 06402
2 Faults Found:
Readiness: N/A
Coding: 0001025
Coding: 00043
Shop #: WSC 00046
7 Faults Found:
Coding: 13113
Shop #: WSC 06441
1 Fault Found:
Coding: 05122
Shop #: WSC 03429
2 Faults Found:
Coding: 00006
Shop #: WSC 06402
Coding: 00259
Shop #: WSC 06402
3 Faults Found:
Re: PROBLEMAS CODIGOS DE ERROR VAG COM
Publicado: 23 Feb 2013 18:55
Tiene muchísimos errores puede ser que se haya quedado sin batería y la falta de voltaje haya provocado todos esos errores, bórralo todo y haz el scan de nuevo seguro que saldrán muchos menos o ninguno.
Publicado: 23 Feb 2013 19:10
por jero
la bateria se la e tenido que desconectar ya que el coche esta continuamente abriendose solo cuando ya esta abierto y lo hace muy seguido como si estubiera todo el rato con la llave pulsando el boton de abrir una cosa rarisima y he tenido que quitar el cable de la bateria para que se quede cerrado porque esta en la calle.
Publicado: 23 Feb 2013 20:50
por jero
hola, tenias razon e borrado los problemas y ahora aparecen menos, este es el scan traducido a español:
Versión VCDS: Release 11.11.3
Versión de datos: 20120401
Sábado, 23 de febrero, 2013,20:17:30:32264
Tipo de chasis: 1M - Seat Leon / Toledo
VIN: VSSZZZ1MZ3R024893 Kilometraje: 251160km/156063miles
Dirección 01: Motor Etiquetas: Fail Redir!
   Número de parte: 038 906 012 FK
   Componente: 1,9 l R4 EDC 0000SG 3357
   Codificación: 00002
   Shop #: WSC 06402
1 Fallo Encontrados:
18062 - Por favor, verifique la memoria DTC del Grupo de instrumentos
            P1654 - 35-10 - Intermitente
Preparación: N / A
Dirección 03: Frenos ABS Labels: 1C0-907-37x-ABS.lbl
   Número de parte: 1C0 907 379 L
   Componente: ABS FRONT MK60 0101
   Codificación: 0001025
No hay código de error encontrado.
Dirección 08: Auto HVAC Labels: 1M0-820-043.lbl
   Componente: 1M-CLIMATRONIC X0603
   Codificación: 00043
   Shop #: WSC 00046
2 Los fallos encontrados:
00604 - Potenciómetro servomotor para chapaleta de Flujo de Aire (G113)
            30-00 - Abierto o corto a más
Dirección 15: Airbags Labels: 6Q0-909-605-VW5.lbl
   Número de parte: 1C0 909 605 A
   Codificación: 13113
   Shop #: WSC 06441
Dirección 17: Instrumentos Labels: 1M0-920-XX2-17.lbl
   Número de parte: 920 802 1M0 D
   Componente: KOMBI + WEGFAHRSP VDO V03
   Codificación: 05122
   Shop #: WSC 03429
00562 - Sensor de nivel de aceite / temperatura (G266)
Dirección 19: etiquetas de las latas de puerta de enlace: 6N0-909-901-19.lbl
   Componente: Gateway K <-> CAN 0001
   Codificación: 00006
   Shop #: WSC 06402
Dirección 46: Central Conv. Etiquetas: 1C0-959-799.lbl
   Número de parte: 1C0 959 799 F
   Componente: 3E Komfortgerát 0003 HLO
   Codificación: 00259
   Shop #: WSC 06402
   Subsistema 1 - Número de parte: 1C1959801A
   Componente: 3E KLO Tõrsteuer.FS 0004
   Subsistema 2 - Número de parte: 1C1959802A
   Componente: 3E Tõrsteuer.BF KLO 0004
   Subsistema 3 - Número de parte: 1C0959811A
   Componente: 3E Tõrsteuer.HL KLO 0004
   Subsistema 4 - Número de parte: 1C0959812A
   Componente: 3E Tõrsteuer.HR KLO 0004
00928 - Módulo de bloqueo para bloquear Central, del lado del conductor delantero (F220)
            27-00 - señal no plausible
Fin ------------------------------------------------- --------------------
Publicado: 24 Feb 2013 10:46
A mi parecer te falla la cerradura del conductor, yo probaría desenchufandola y probar así en teoría debería funcionar de forma normal pero claro la del conductor estaría en modo mecánico.
Si es así solo tendrías que reparar o sustituir la cerradura, por aquí hay un manual mio sobre ello, aunque ya te advierto que es no es fácil hacerló.
Publicado: 24 Feb 2013 11:46
por jero
yo tambien pienso que debe de ser eso ya que afecta a las luces de dentro cuando abro la puerta se apagan las luces de dentro del coche, asique probare lo que me dices y vere el manual que me dices aver si lo puedo hacer y sino pues tendre que comprar dos ceraduras ya que la del copiloto esta igual.
ya os contare como me a ido la cosa.
Publicado: 25 Feb 2013 23:45
por jero
bueno pues hoy he desmontado la cerradura y he estado probando el botoncito que activa la luz y la luz no encendia, alfinal voy a tener que poner una de desguace o nueva uffff, de los otros errores que me da el vag com que me decis que es lo que tengo que cambiar o reparar?
Publicado: 09 Mar 2013 00:45
por jero
bueno pues ya esta todo solucionado doy el post por solucionado, efectivamente eran la cerradura, al final me decante por poner una nueva y ya va todo ok, gracias por las respuestas.
