Hola soy Luis con un tema que haber si podemos echar una mano a un forero del Seat Leon
Es lo siguiente se le enciende la luz del TCS y el VAGCOM LE da este error
17656 Injection Star Regulation Control Deviation
P1248-35-10----Intermitent
Readness N/A
Ha cambiado ya el interruptor del pedal del freno,ya que unas veces le enciende las luces de freno y otras no
Si alguien me puede ayudar a iluminar a este chico se lo agradecere y el tambien
LUZ TESTIGO TCS/ESP
Re: LUZ TESTIGO TCS/ESP
17656/P1248/004680 - Start of Injection Timing Regulation: Control Deviation
Possible Symptoms
Loss of Power at high Engine Speeds
Engine difficult to Start
Possible Causes
Start of Injection Timing Regulation not OK
Injection Pump Control Range blocked/dirty (e.g. by Metal Particles)
Engine has stalled / ran out of Fuel recently
Wiring/Connectors from/to Injection Valve (N108) faulty
Possible Solutions
Check/Adjust Injection Start. See TDI Timing Checker
Check Fuel Supply
Check/Replace Fuse(s)
Check/Repair Wiring/Connectors from/to Injection Valve (N108)
Run Output Tests
Special Notes
Might by stored with other codes like 17654/P1246/004678.
When stored in the VW (9M/1J) Golf/Jetta or (1C) Beetle with the ALH engine code Tech Tip 23-02-03 may be helpful. The summary involves removing power at idle to the N108 Cold Start Injection Valve (Fuse 34 on those body styles) while monitoring Basic Setting group 000.2 which is shown under "Timing" when using the TDI Timing Checker. When power is removed from N108 the live reading should change to 255
Possible Symptoms
Possible Causes
Possible Solutions
Check Fuel Supply
Run Output Tests
Special Notes
