PROBLEMAS CODIGOS DE ERROR VAG COM
hola e hecho un scan a mi toledo y no se interpretar que arreglo tiene si lo puedo hacer con el vagcom todo o alguna cosa hay que sustituir, este es el escaner:
VCDS Version: Release 11.11.3
Data version: 20120401
Saturday,23,February,2013,16:01:33:32264
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ3R024893 Mileage: 251160km/156063miles
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 012 FK
Component: 1,9l R4 EDC 0000SG 3357
Coding: 00002
Shop #: WSC 06402
VCID: 5EB980A1DA2CB49
VSSZZZ1MZ3R024893 SEZ7Z0B1632852
2 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - Intermittent
17948 - Vehicle Speed Signal
P1540 - 35-00 - Signal too High
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 00001 001 00001
VCID: 336F0115512E491
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 C
Component: 1M-CLIMATRONIC X0603
Coding: 00043
Shop #: WSC 00046
VCID: 2241F451AED4D09
7 Faults Found:
00603 - Footwell/defroster Flap Positioning Motor (V85)
41-10 - Blocked or No Voltage - Intermittent
01272 - Positioning Motor for Central Flap (V70)
01271 - Positioning Motor for Temperature Flap (V68)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-00 - Open or Short to Plus
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
00797 - Sunlight Photo Sensor (G107)
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0004
Coding: 13113
Shop #: WSC 06441
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 802 D
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05122
Shop #: WSC 03429
VCID: 2757E545C5F6351
2 Faults Found:
00562 - Sensor for Oil Level/Temperature (G266)
00667 - Ambient Temperature Signal
30-10 - Open or Short to Plus - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
VCID: F0E54E19B0B8B29
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: 3E Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 06402
VCID: 3A712C312644B89
Subsystem 1 - Part No: 1C1959801A
Component: 3E Tõrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C1959802A
Component: 3E Tõrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811A
Component: 3E Tõrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812A
Component: 3E Tõrsteuer.HR KLO 0004
3 Faults Found:
01389 - Tailgate Open Switch (F124)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00930 - Locking Module for Central Locking; Rear Left (F222)
End ---------------------------------------------------------------------
Saturday,23,February,2013,16:11:32:32264
Coding: 00002
Shop #: WSC 06402
2 Faults Found:
Readiness: N/A
Coding: 0001025
Coding: 00043
Shop #: WSC 00046
7 Faults Found:
Coding: 13113
Shop #: WSC 06441
1 Fault Found:
Coding: 05122
Shop #: WSC 03429
2 Faults Found:
Coding: 00006
Shop #: WSC 06402
Coding: 00259
Shop #: WSC 06402
3 Faults Found:
Coding: 00002
Shop #: WSC 06402
2 Faults Found:
Readiness: N/A
Coding: 0001025
Coding: 00043
Shop #: WSC 00046
7 Faults Found:
Coding: 13113
Shop #: WSC 06441
1 Fault Found:
Coding: 05122
Shop #: WSC 03429
2 Faults Found:
Coding: 00006
Shop #: WSC 06402
Coding: 00259
Shop #: WSC 06402
3 Faults Found:
Coding: 00002
Shop #: WSC 06402
2 Faults Found:
Readiness: N/A
Coding: 0001025
Coding: 00043
Shop #: WSC 00046
7 Faults Found:
Coding: 13113
Shop #: WSC 06441
1 Fault Found:
Coding: 05122
Shop #: WSC 03429
2 Faults Found:
Coding: 00006
Shop #: WSC 06402
Coding: 00259
Shop #: WSC 06402
3 Faults Found:
Re: PROBLEMAS CODIGOS DE ERROR VAG COM
Tiene muchísimos errores puede ser que se haya quedado sin batería y la falta de voltaje haya provocado todos esos errores, bórralo todo y haz el scan de nuevo seguro que saldrán muchos menos o ninguno.
la bateria se la e tenido que desconectar ya que el coche esta continuamente abriendose solo cuando ya esta abierto y lo hace muy seguido como si estubiera todo el rato con la llave pulsando el boton de abrir una cosa rarisima y he tenido que quitar el cable de la bateria para que se quede cerrado porque esta en la calle.
hola, tenias razon e borrado los problemas y ahora aparecen menos, este es el scan traducido a español:
Versión VCDS: Release 11.11.3
Versión de datos: 20120401
Sábado, 23 de febrero, 2013,20:17:30:32264
Tipo de chasis: 1M - Seat Leon / Toledo
VIN: VSSZZZ1MZ3R024893 Kilometraje: 251160km/156063miles
Dirección 01: Motor Etiquetas: Fail Redir!
Número de parte: 038 906 012 FK
Componente: 1,9 l R4 EDC 0000SG 3357
Codificación: 00002
Shop #: WSC 06402
1 Fallo Encontrados:
18062 - Por favor, verifique la memoria DTC del Grupo de instrumentos
P1654 - 35-10 - Intermitente
Preparación: N / A
Dirección 03: Frenos ABS Labels: 1C0-907-37x-ABS.lbl
Número de parte: 1C0 907 379 L
Componente: ABS FRONT MK60 0101
Codificación: 0001025
No hay código de error encontrado.
Dirección 08: Auto HVAC Labels: 1M0-820-043.lbl
Componente: 1M-CLIMATRONIC X0603
Codificación: 00043
Shop #: WSC 00046
2 Los fallos encontrados:
00604 - Potenciómetro servomotor para chapaleta de Flujo de Aire (G113)
30-00 - Abierto o corto a más
Dirección 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Número de parte: 1C0 909 605 A
Codificación: 13113
Shop #: WSC 06441
Dirección 17: Instrumentos Labels: 1M0-920-XX2-17.lbl
Número de parte: 920 802 1M0 D
Componente: KOMBI + WEGFAHRSP VDO V03
Codificación: 05122
Shop #: WSC 03429
00562 - Sensor de nivel de aceite / temperatura (G266)
Dirección 19: etiquetas de las latas de puerta de enlace: 6N0-909-901-19.lbl
Componente: Gateway K <-> CAN 0001
Codificación: 00006
Shop #: WSC 06402
Dirección 46: Central Conv. Etiquetas: 1C0-959-799.lbl
Número de parte: 1C0 959 799 F
Componente: 3E Komfortgerát 0003 HLO
Codificación: 00259
Shop #: WSC 06402
Subsistema 1 - Número de parte: 1C1959801A
Componente: 3E KLO Tõrsteuer.FS 0004
Subsistema 2 - Número de parte: 1C1959802A
Componente: 3E Tõrsteuer.BF KLO 0004
Subsistema 3 - Número de parte: 1C0959811A
Componente: 3E Tõrsteuer.HL KLO 0004
Subsistema 4 - Número de parte: 1C0959812A
Componente: 3E Tõrsteuer.HR KLO 0004
00928 - Módulo de bloqueo para bloquear Central, del lado del conductor delantero (F220)
27-00 - señal no plausible
Fin ------------------------------------------------- --------------------
Codificación: 00002
Shop #: WSC 06402
Preparación: N / A
Codificación: 00043
Shop #: WSC 00046
Codificación: 13113
Shop #: WSC 06441
Codificación: 05122
Shop #: WSC 03429
Codificación: 00006
Shop #: WSC 06402
Codificación: 00259
Shop #: WSC 06402
A mi parecer te falla la cerradura del conductor, yo probaría desenchufandola y probar así en teoría debería funcionar de forma normal pero claro la del conductor estaría en modo mecánico.
Si es así solo tendrías que reparar o sustituir la cerradura, por aquí hay un manual mio sobre ello, aunque ya te advierto que es no es fácil hacerló.
yo tambien pienso que debe de ser eso ya que afecta a las luces de dentro cuando abro la puerta se apagan las luces de dentro del coche, asique probare lo que me dices y vere el manual que me dices aver si lo puedo hacer y sino pues tendre que comprar dos ceraduras ya que la del copiloto esta igual.
ya os contare como me a ido la cosa.
bueno pues hoy he desmontado la cerradura y he estado probando el botoncito que activa la luz y la luz no encendia, alfinal voy a tener que poner una de desguace o nueva uffff, de los otros errores que me da el vag com que me decis que es lo que tengo que cambiar o reparar?
bueno pues ya esta todo solucionado doy el post por solucionado, efectivamente eran la cerradura, al final me decante por poner una nueva y ya va todo ok, gracias por las respuestas.
